查看: 6875|回复: 5
Omega Block / Daniel Bonilla Arquitectos
发表于 2010-4-16 12:51:13 | 显示全部楼层 |阅读模式
Architects: Daniel Bonilla Arquitectos
Client: Colegio Anglo Colombiano
Project Team: Daniel Bonilla, Adriana Hernández, David Córdoba, Juan Andrés Díaz, Andrés Gutiérrez, Eduardo Varela.
Collaborators: Paula Gutiérrez, Alejandra Torres, Vanessa Vásquez, Sebastián Chica, Nicolás Carpio.
Project Area: 3,200 sqm
Project Year: 2008-2009
Photographs: Rodrigo Dávila
 楼主| 发表于 2010-4-16 12:57:42 | 显示全部楼层
The Omega Block Building, located in the Anglo Colombiano School, is the summary of three buildings in progression, which are adapted to the morphology of the triangular area disposed for its development.
欧米茄大厦,位于英属哥伦比亚人学校。三个递进的建筑体量,是为了适应三角形的用地而演变出来的形态。
 楼主| 发表于 2010-4-16 13:04:14 | 显示全部楼层
A grand staircase, or tiered seating, ensures a fluid connection between the base plane (ground floor) with level above, while offering a congregational space. With this element, the scale of the building changes, and re-interprets the use of the atrium space.
一个宽大的楼梯,或休息平台,连接了不同的楼层,从而使得空间得以流动,同时提供了一处聚集的空间。通过这个楼梯,使得建筑的规模体量发生了变化,并重构了一种新型的中厅空间。
 楼主| 发表于 2010-4-16 13:13:05 | 显示全部楼层
The dominant materiality of the project, large format brick and slender pre-stressed concrete elements (beige in color), binds the outside spaces with that of the large internal atrium space. Further tonal and material compliment is found in the vibrant green special divisions (doors and divisions), with smooth Formica finish.
该项目主要材料是大而扁平的外墙砖和细长的预应力混凝土(颜色米黄色),通过一个宽敞的内部中庭空间与外部空间有机结合在了一起。一些细部的处理和刻画比如外墙面绿色的凹进的洞口和材料的精心选择等等,都使得建筑增色不少。
发表于 2010-4-16 13:13:31 | 显示全部楼层
怎么一张图片  还想多看点呢
 楼主| 发表于 2010-4-16 13:17:59 | 显示全部楼层
更多图片:
© Rodrigo Davila © Rodrigo Davila © Rodrigo Davila
© Rodrigo Davila plan 01 plan 02
elevations section 01 section 02
details
