查看: 5008|回复: 3
Les Ti’Canailloux / Topos Architecture
发表于 2010-3-12 04:20:48 | 显示全部楼层 |阅读模式
建筑师: Topos Architecture
地点: Nantes, France
客户: Association “Les Ti’Canailloux”
项目面积: 350 sqm
建造年份: 2008-2009
摄影: Patrick Miara
The nursery is located in Nantes, on a woody parcel of 700 sqm, at the corner of two streets, in a residential area. The Architects opted for an original urban building, in harmony with the district. In this way, the nursery is based on a jewellery box: the high volumes seem to come unfolded from an initial central volume. It looks like a big house.
托儿所座落在法国南特一个居民区内。建筑面积700平方米,用木材包裹,座落于在两条街道的角落。建筑师选择了一种原著民的建筑形态以取得城市建设与社区和谐。这样,托儿所是(基于宝物盒之上)?:高容积的空间似乎是从最初的中心空间展开。它看起来像一个大房子。
 楼主| 发表于 2010-3-12 04:43:03 | 显示全部楼层
1267800428-canailloux-06-800x1000.jpg Constructive system:
The nursery was designed in order to give, at the building’s back, a protected and quiet children’s garden with trees.
The main building material is the wood (European Larch). It is used for the frame, the vertical cladding and the roof. It entirely covers the building. The Larch was processed without chemicals, but with an innovative technology based on old times techniques: “Oléothermie”. The wood is impregnated with vegetables oils that have proprieties against fungus.
建筑系统:
托儿所的目的是为了在建筑物的庇护之下提供一个受保护和安静的孩子们的树园。
主要建材是木材(欧洲落叶松)。它用在建筑框架,垂直面和屋顶。它覆盖整个建筑。落叶松是未经化学处理的,而是采用了一种具有创新技术为基础的,古老的的技术:“Oléothermie”。木材是用经过蔬菜油浸渍的从而对真菌有抵御能力。
 楼主| 发表于 2010-3-12 04:43:44 | 显示全部楼层
回复 2# sam
发表于 2010-3-27 10:10:26 | 显示全部楼层
学习了。感觉幼儿园的元素少了点。
