查看: 5750|回复: 2
Split Level House by Qb
发表于 2010-1-12 02:22:47 | 显示全部楼层 |阅读模式
Design studio Qb of Philadelphia have completed a house in Philadelphia that features a glazed interior wrapped in a curved brick facade.
费城的Qb设计工作室完成了当地的一个住宅项目,它有着曲面的砖墙和大面积的玻璃窗。
Called Split level House, the three-storey residence is located on the corner of two streets and is elevated just above street level.
它被称为分层住宅,它有3层,位于街道的角落,位于街道水平面以上。
The interior features bleached and blackened oak, polished concrete and steel.
内部采用原色和黑色漆的橡木,还用了抛光的混凝土和钢材。
A roof terrace is enclosed by the top of the brick skin.
屋顶平台由砖女儿墙包围。
Here’s some more information from Qb:
下面是来自于Qb的详细信息:
Sited on a vacant corner in Philadelphia, this newly constructed house stitches itself into the neighborhood by responding to local cues.
新建的住宅位于费城的角落,它通过与本地的环境相呼应来设置融于环境。
Curved brick corners negotiate the irregular street grid, while the cadence of typical rowhouses and a palette of brick volumes and stone bases are translated into a new vocabulary.
弧线型的砖墙顺应了街角,联立式房屋的典型节奏、砖墙的材质和石阶给当地的环境加入了新的词汇。
A three story brick skin wraps the glass-lined interior, forming intimate exterior spaces where the two diverge.
三层的砖表皮包裹起玻璃分割为主的内部空间并使两种材质亲密配合。
An interior palette of bleached and blackened oak, polished concrete and patinaed steel contrast the rich wood, hammered concrete and brick of the exterior.
内部采用原色和染色的橡树木板,抛光的混凝土和钢材,与外表皮的材质形成对比。
Floating just above the streetscape, the interior spaces wrap around the three-story glass entry, framing views out and back into the house. The brick skin shelters the interior and becomes the roof garden parapet, creating a sense of complete privacy.
室内空间由一些玻璃墙分隔,可以从室内俯瞰街景,也可以看到不同的房间。砖墙包裹着住宅,并且也是屋顶平台的女儿墙,获得私密感。
发表于 2010-1-18 03:06:20 | 显示全部楼层
好久没看到了
发表于 2010-3-9 06:21:04 | 显示全部楼层
路转角的house~
