查看: 8298|回复: 6
House KvD / Grosfeld van der Velde Architecten
发表于 2010-1-12 02:02:51 | 显示全部楼层 |阅读模式
Architects: Grosfeld van der Velde Architecten
Client: Private
Project Year: 2007-2009
Photographs: Rene de Wit
House KvD is located in the woods of Teteringen, close to Breda. Important, from the residents point of view, was to experience the green environment in a most intense way. This ambition has formed the main concept of the building: A house that feeds in between the trees, giving every arbitrary movement a surprising perspective on the forest. The square-shaped volume keeps you, while moving through the building, in constant contact with the environment.
House KvD座落于泰特灵恩树林,接近布雷达。重要的是在当地居民的观点看来,应该最强烈的方式绿化环境。这种强烈的想法,促成了建筑物设计的主要概念:一个在树林间成长的房子,一个从任意的运动的角度都能呈现出很精彩的画面的房子。方方正正的室内空间由您安排布置,同时在建筑中通过移动穿行,时刻与周围环境的密切接触。
The square, that’s partly lifted by piles, embraces an open courtyard on which the entrance is situated. The living rooms are located on ground zero, the bedrooms are lifted and provided with horizontal orientated windows. The framework, situated on the outside of the building, are filtering direct incoming sunlight and give a beautiful ‘cut out’ view of the forest. They also intensify the sculptural characteristic of the volume. The façade is made of vertically placed black stained wooden parts. The subtle details in combination with shape and material make the house modern, but also reserved in it’s afforested environment.
内庭院,由一个位于入口上之上被柱子架起来的部分环抱、围合出一个开放的院子。起居室位于地面为零标高,卧室被抬高并设置了一个横向的长条窗。建筑外部出挑的檐口、框架构件,不仅是考虑到遮挡直接照射的阳光,并提供了动人美丽的森林的意向。他们还特意强化了建筑的雕塑感。立面是由垂直放置的黑色防腐木组成。造型和材料相结合的微妙细部使得房屋不但表现出现代的设计理念,也使得原来的绿化环境得以保留。
 楼主| 发表于 2010-1-12 02:07:45 | 显示全部楼层
 楼主| 发表于 2010-1-12 02:16:16 | 显示全部楼层
发表于 2010-1-13 04:30:55 | 显示全部楼层
很干净的室内空间,设计手法也很简洁。
发表于 2010-1-18 04:11:45 | 显示全部楼层
喜欢~
发表于 2010-1-29 12:35:22 | 显示全部楼层
这些立面的开窗到底怎么控制的啊??
发表于 2010-3-23 09:01:32 | 显示全部楼层
看国外的做工都特别干净。
