查看: 5713|回复: 2
the pavilion in Munich --- 翻译 11-19-2009
发表于 2009-11-19 14:25:07 | 显示全部楼层 |阅读模式
网站来源:http://www.archdaily.com/
Coop Himmelb(l)au has designed a temporary mobile performance space for the Bavarian State Opera in Munich, Germany.  The pavilion will house performances during the annual Opera Festival  in 2010, and once that festival is over, the pavilion will be reassembled in various locations.  Designed to “give the impression of a quieter environment,” the pavilion reduces the apparent noise  to create a ‘zone of silence’ where visitors can sense a change in the soundscape.
More images and more about the pavilion after the break.
   Coop Himmelblau为德国慕尼黑的巴伐利亚歌剧中心设计了一个可移动的演出空间。 这个临时的演示空间将为2010年的歌剧院周年庆典提供场所,并且当庆典结束后,这个移动空间将会在不同的地方进行重新组装。在这个空间中放置了消声设备,这个移动演出厅的创早出了噪声大为改观的静音区,继而参观者会感受到不一样的声环境。
发表于 2009-11-19 15:18:50 | 显示全部楼层
还没翻完,后面还有一段,你打开那个链接就看到了,呵呵
发表于 2009-11-20 00:07:53 | 显示全部楼层
:30~而且有错别字
