查看: 6015|回复: 4
Anzac Hall 澳新军团纪念大厅
发表于 2009-11-15 09:44:31 | 显示全部楼层 |阅读模式
Anzac Hall / Denton Corker Marshall
澳新军团纪念大厅/DCM公司
来源:http://www.archdaily.com/
链接:http://www.archdaily.com/40408/anzac-hall-denton-corker-marshall/
    Architect: Denton Corker Marshall
    Client: Australian War Memorial
    Exhibition Designers: Freeman Ryan
    Project area: 3,000 sqm
    Project year: 2004
    Photographs: John Gollings
ANZAC Hall extends the Australian War Memorial, providing 3,000 sqm of exhibition space to display the large technology relics in the Memorial’s collection, such as aircraft, vehicles, tanks and other ordnance.
澳新军团纪念大厅是澳大利亚战争纪念馆的扩建部分,建筑提供3000平方米的展示空间,用来陈列纪念馆的大型展品,如飞机,汽车,坦克以及其他军械等。
The Australian War Memorial is sited at one of Canberra’s most important locations: the main Land Axis that defines the city plan, and is therefore visually linked with Parliament House. To preserve the historic view from ANZAC Parade, ANZAC Hall is positioned to the rear of the Australian War Memorial and is recessed into the landscape below and behind a wall, thereby minimizing the impact on the existing landmark.
澳大利亚战争纪念馆位于堪培拉最重要的位置:它处于控制了整个城市平面的城市中轴线上,同时在视线上与国会大厦遥相呼应。为了保持从澳新军团游行广场而来的视线得以延续,纪念大厅被选择置于战争纪念馆的后方,将其隐藏在景观之中和一面墙的背后,使新建的建筑对已有的地标的影响达到最小。
The fan-shaped building comprises a long solid concrete wall that tapers dramatically to a thin edge at each end. A dark thin curving roof cantilevers over the main body of the building, adopting the appearance of the wing of a military aircraft. With no direct public access through its exterior, ANZAC Hall maintains an enigmatic presence on the site and provides a neutral backdrop to the Memorial. Its palette of materials and colours is a fitting reminder of the military nature of the museum.
扇形的建筑包含有一个长长的混凝土墙,这面墙最引人注目的在于它逐渐变窄的两端。一个黑色的薄薄的弯曲的屋顶从建筑向外伸展,就像战斗机的翅膀一样。这座对外没有直接出入口的建筑,以迷一般的姿态坐落在场地上,低调地成为了战争纪念馆的背景。建筑材料和颜色的选择和纪念馆的战争题材这一性质非常吻合。
1257855995-anzac-hall-02-p-450x900.jpg 1257856006-anzac-hall-05.jpg 1257856019-anzac-hall-perspective-from-the-north.jpg 1257856026-ground-floor-plan-1000x707.jpg 1257856017-anzac-hall-sketch-01-1000x339.jpg 1257856014-anzac-hall-photo-001.jpg 1257856009-anzac-hall-07.jpg
 楼主| 发表于 2009-11-15 09:45:44 | 显示全部楼层
感觉有些太不连贯
翻译真不是一件容易的事。才知道老大前些日子原来那样辛苦。
 楼主| 发表于 2009-11-15 09:48:36 | 显示全部楼层
随后可以把我拍的照片补上
发表于 2009-11-16 05:17:08 | 显示全部楼层
老2,又去哪里转悠撒
 楼主| 发表于 2009-12-7 15:02:09 | 显示全部楼层
自己拍的一些照片
从纪念馆背后的山下来看新馆与旧馆
从纪念馆背后的山下来看新馆与旧馆
新馆半隐藏于地下
新馆半隐藏于地下
锐利的墙面
锐利的墙面
联系新旧之间的玻璃连廊
联系新旧之间的玻璃连廊
一面墙体将新旧馆分隔开,墙体材料与旧馆统一,且在新旧馆之间形成以人流可以穿越的通道
老馆庭院中轴线
老馆庭院中轴线
老馆主体建筑
老馆主体建筑
从入口看堪培拉城市中轴线,对面是国会大厦
每个拱下刻着和澳大利亚交战过的国家,这里有中国。是澳洲参加朝鲜战争的事情
老馆
老馆
